Printing Issue
When printing the ROI YIELD and DISTRIBUTION SUMMARY reports, the leftmost portion of each line is truncated -- about half the first letter. I've tried adjusting the L/R margins and font size and that makes no difference in the truncation. Other reports print correctly.
Hi elliots,
If you look in the "Print Preview" is it truncated there as well?
Hi elliots,
I suspect this is some problem specific to your printer or driver. Fund Manager uses the same code to draw the Print Preview window as it sends to the printer, so they should be identical. I also just did a test print of these reports here, and they printed properly. I'd suggest seeing if your printer has an updated driver available. Do you have another printer you can try printing on?
I think I've got it fixed. First, I was wrong -- it did show on the preview. It appears that the problem was that I was setting to close a L Margin. When set to 0.25, I get the clipping; at 0.30 it's fine. Some of your reports seem pretty wide for letter size paper. On the Distribution Summary report I had to reduce the font to 8 with margins of 0.3/0.25 and also some column width adjustments.
Hi elliots,
Great, glad you fixed it. Yes, some printers aren't able to print that close to the edge of the paper.
Who is onlineUsers browsing this forum: No registered users and 15 guests |
