Insufficient Memory Error
Postby ElGordo » Sun Sep 22, 2019 9:36 am
I have the Fund Manager software installed on my home PC and on my work PC and when I try to print my reports I am getting an error message that there is insufficient memory and the printed report is BLANK. Have tried printing to a printer and also printing to a PDF and I get the same message.
ElGordo
Postby Mark » Mon Sep 23, 2019 8:15 am
Hi ElGordo,
1) What version of Fund Manager are you using? See "Help / About...".
2) Do you get this same error on both of your PCs?
3) Is this error happening only on a certain report, or on all reports? For example, if you create a simple Portfolio Value report on a small account, does that print?
4) Can you print a graph window okay? Can you print from "File / Print / All Transactions..." okay?
Postby ThomasK » Thu Feb 17, 2022 10:16 am
I read through the threads for "Insufficient Memory" and notice that my issue was not covered.
I'm trying to print a memorized Custom Report that I've printed before but now I get either:
a. an "Insufficient Memory" error and no display
b. a display of the Preview but prints a blank page
c. when I unchecked "Scale Down" it will print but of course truncates rightmost columns.
HOWEVER, a newly opened Report (it's memorized) prints OKAY.
Sure, I can simply close the offending report and reopen it but I'm wondering if there is some sort of permanent fix. Not a big deal but I thought you might have some insights as the issue comes and goes.
NOTES:
- I was rearranging my reports when the error occurred
- I have the following open on 4 monitors/4k monitor:
- the portfolio editor
- an 8-column custom holdings report (printed on letter, portrait)
- a 5-column custom alerts report (printed on letter, portrait)
- and the offending 21-column custom everything report (printed on legal, landscape)
- FM version 2018.15.5.100
- I'm using a pretty decent ThinkPad workstation BUT I keep a lot of stuff open so that I sometimes get to 70% memory used and the issue resolved itself after reopening the report
Postby Mark » Thu Feb 17, 2022 12:56 pm
Hi ThomasK,
The first thing I would ask is if the problem can be reproduced on the latest version? I would also check to see if the problem changes when you print to a different printer, or to a lower resolution?
Postby Djobydjoba » Sun Jan 05, 2025 10:29 am
I too have the Insuffisent Memory Error pop-up with a Report Print Preview or when launching the printing to the Microsoft Print to PDF printer.
The report is a Portfolio Performance report (not custom) with maybe 200 lines.
My computer has 32 GB of RAM, 15Go used currently...
Postby Mark » Tue Jan 07, 2025 7:42 am
1) Did this used to work?
2) What screen resolution are you using?
3) If you turn off "File / Page Setup... / Scale Down to 1 Page Wide When Necessary", does that fix the issue?
Postby Djobydjoba » Tue Jan 14, 2025 11:05 am
I can't reproduce the problem anymore. A few days ago he often repeated. What I noticed then:
- It was working with lighter reports (less lines)
- It was working with "File / Page Setup... / Scale Down to 1 Page Wide When Necessary" turn off, but not when turned on.
- It was working with Exchange Rate Adjusted ON, but not with Exchange Rate Adjusted OFF (I played at least 5-6 times with this setting to confirm, I was happy to find this but, maybe after a FM restart, the problem has gone).
My screen resolution : 1920*1200
I can't reproduce it now, I will try again in the future (even if it's not a feature I use much)
