Yield = NA
Postby VFP9Belgium » Tue Oct 15, 2019 11:15 pm
FM2020 - Portfolio Editor screen
I notice that some investments have Yield 3m = NA while Yields 6m, 1y and 3 y for the same investments show percentages.
It concerns investments I own for more than a year and that have daily price updates.
How can Yield 3m be NA while Yield 6m has a value?
Regards
Alan
VFP9Belgium
Postby Mark » Wed Oct 16, 2019 9:15 am
Hi Alan,
You are likely missing prices 3 months ago. If you look at your yield interpolation range settings there is an option for how many days you will allow interpolation for a missing price period. Look in the Data Register under the "Prices" data type for 3 months back from the current date (which is the date used by this Portfolio Editor field), and see if you have a gap in pricing.
If this is not the reason, create a ROI Yield report ending today with this same 3M yield term, and it should also show NA. You can then look under "Help / Logs / Report Calculation..." for an explanation of the NA figure.
Postby VFP9Belgium » Thu Oct 17, 2019 11:50 pm
Hi Mark
Thanks for the clear instructions; I was able to figure it out.
Regards
Alan :D
VFP9Belgium
