Report columns misaligned
Postby Djobydjoba » Sat Oct 19, 2019 2:19 am
Sometimes the columns become misaligned in my (custom) reports. This often occurs when playing with the Exchange Rate Adjusted option on /off (Ctrl+X).
Another example :
https://i.postimg.cc/7YYTZ5Xq/20191019-sam-11h22-01.png
I can even say this bug is systematic just for now. Playing with Ctrl+X repeatedly causes random results in alignment.
But I've restarted FM and the bug is gone...
Postby Mark » Sat Oct 19, 2019 6:31 pm
If you see this issue come back, please check the following:
1) Do you have more than 1 Custom report window open? If you do, try closing all but 1 of the Custom report windows, and see if that fixes it.
2) When you see it happen, if you simply resize the problematic window, forcing it to re-draw, does that clear up that window?
Postby Djobydjoba » Sun Oct 20, 2019 8:17 am
Mark wrote:1) Do you have more than 1 Custom report window open?
Yes, you're right. Seems it can occur when two or more custom reports are open.
I can reproduce now, but it depends on which custom reports are open.
Mark wrote:try closing all but 1 of the Custom report windows, and see if that fixes it.
Yes, that fixes it.
Mark wrote:if you simply resize the problematic window, forcing it to re-draw, does that clear up that window?
Yes.
Postby Mark » Sun Oct 20, 2019 10:42 am
Thanks. The source of the issue here is that Custom reports memorize column sizes globally, and not on a per-report basis. That means if you have field X in multiple Custom reports, the last place you (or the automatically sizing algorithm) sets the width for field X in any Custom report, that will apply to all Custom reports with field X. If a report window gets partially re-drawn you can sometimes get drawing artifacts like this. It is usually pretty rare though.
