%Gain-F (btw) in a user-defined field
Postby Djobydjoba » Sun Dec 08, 2019 7:02 am
I look for the way to include "%Gain-F (btw)" in the equation of a user-defined field.
It seems not directly available, so I used the formula: 100*(NAVchange_btw/End_NAV)
But the results are not always the same that "%Gain-F (btw)".
Could you help?
Postby Mark » Sun Dec 08, 2019 8:58 am
Any differences would be because the %Gain-F includes distributions/share in the equation. The %Gain-F (between) is available for user-defined fields. It is called:
PGainF_btw
The field names can be cryptic sometimes, but if you use the filter by type dropdown at the top of the "Insert Field Into Equation" dialog, that can help find them more easily.
Postby Djobydjoba » Sun Dec 08, 2019 1:10 pm
Great. I don't know how I missed that field... Thanks.
Postby Djobydjoba » Sat Dec 14, 2019 9:51 am
A question again, It seems a custom field property can be inserted in a equation (in an If function), but this doesn't work for me.
For example, a custom property, text type, labeled "Percent".
IF(Percent == Yes, 100*NAVchange_btw, PGainF_btw)
Return "Invalid equation"...
Postby Mark » Sat Dec 14, 2019 3:52 pm
You can only insert a "Custom Investment Property" into a user-defined equation if that property is designated as a number or a date. If it is assigned to be "text", it won't be available. If you use the "Insert Field..." button, you can pick from any available fields, and any number or date type custom investment properties will be listed, but not the text ones.
Postby Djobydjoba » Sat Dec 14, 2019 11:49 pm
Got it, thanks!
