Setting "Today" For Custom Reports
Postby B2B_Investing » Mon Jun 01, 2020 8:46 am
I am having some trouble setting "today" as the timeframe for some custom reports. It seems to keep the date that I memorize the report or changes to a "custom" date range. If the desired end results is to memorize a "todays" date and will always be "today" when I run the memorized report, how do I mark the "Float End Date" and the "Stating Date Relative to End Date" options when I memorize the report?
Jason
B2B_Investing
Postby Mark » Mon Jun 01, 2020 8:51 am
Hi Jason,
You would want to check both of those options when memorizing a report. Also, for determining the actual date "floated" to, see the settings under "Options / Report Preferences... / Other / Memorized Reports: / End Date Floats To:".
