Custom reports across portfolios
When in a given portfolio, for example while in Portfolio1 I run a report from the list included in the software, the result is that report for Portfolio1. This does not apply to custom reports. I have custom reports that I use across all portfolios. If in Portfolio2 and I run that same report, the results are for Portfolio1 since that is where it was created. Unless I want to save that report under every single portfolio, I have to run the report, then scroll through the report settings to change the underlying portfolio. How about having custom reports open in the currently active portfolio? Or am I missing something?
Hi wsslsi,
I think you are using "Memorized" reports? You can control which sub-portfolio is used when creating a memorized report. See "Options / Report Preferences... / Other / Memorized Reports: / Recall Using Sub-Portfolio".
Who is onlineUsers browsing this forum: No registered users and 2 guests |
