2 Sided Report?
Postby heidiasst » Tue Nov 10, 2020 10:02 am
Good Morning Mark,
I have several memorized reports and the ones we print our daily
Marshall wants to condense to 2 sided reports.
I can seem to see find a way to make the change.
Also, while I am in there is there a way to have the reports saved
as Alpha Sorting rather than me having to update them every time
I run them?
Many thanks,
Heidi
heidiasst
Postby Mark » Tue Nov 10, 2020 10:07 am
Hello Heidi,
A 2 sided report would happen when printing. This is a function of your printer driver. Some printers support this, and some don't.
If you set the sorting the way you want prior to memorizing a report, when you recall that memorized report, it will be set to the sorting option at the time of memorization.
Postby heidiasst » Tue Nov 10, 2020 10:09 am
Great, I will look into my printer
So, if a report is already memorized, I can not change it?
I would need to memorize a new report?
heidiasst
Postby Mark » Tue Nov 10, 2020 10:12 am
No, you can update a memorized report:
1) Recall the memorized report
2) Make the changes you want
3) Use "Edit / Memorize Report..." and choose to re-save over the existing one
