Date Settings in Custom report are not correctly saved
Postby wiener30 » Wed Nov 18, 2020 12:38 pm
After configuring a custom report with two periods, e.g YTD and Last year, the date settings are not permanently saved.
After leaving FM and restarting, the second date of the second period is wrongly set to YTD.
Uploaed 2 screenshots: the first after configuration and the second after restart.
wiener30
Postby Mark » Wed Nov 18, 2020 12:42 pm
Hi wiener30,
From within a report window, look at:
Options / Report Preferences... / Other / Portfolios: / Float End Date
It sounds like you want that option off, but it will then not float your first date setting to the current date...
Postby wiener30 » Wed Nov 18, 2020 1:37 pm
Thank you.
wiener30
