Issue after updating the latest quote module
I seem to have lost portfolio updates after I installed the latest quote module update (560). It looks like all of my portfolio went back by 3-4 months. How can I get it fixed? I dont have a backup taken recently.
Hi prasannainv,
Installing an update should not have any impact on your data. What specifically are you seeing that is wrong? Fund Manager makes automatic backups. See "Options / General Preferences... / Data".
I did check that folder and the back there was marked for today AM but the contents are 3 months old. So basically all the portfolios went back to Nov time frame. I am missing new customers I added after that and all transaction update on other customers.
That folder should have multiple *.FMB backup files?
Yes they do. I checked on them. Strangely I dont see the customer additions made in the last couple of months. Not sure what I am missing. I had it all visible today AM till I ran the module update. Could I be doing something wrong at my end?
Are you missing clients from "Edit / Client List..." or are you talking about sub-portfolios for your clients?
If you have multiple *.FMB files, you can try restoring from them. I would suggest doing a backup first, using "File / Backup...", so you can get back to where you are now just in case you don't like what is in the backup you restore. Look at the date modified and the size of the *.FMB files to help you decide which one to restore.
I am missing portfolios. I tried multiple back up files. The names of the back up files have changed since November. Not sure if that indicates anything. It looks like i may have to get the customers added and refresh done again.
By default FM saves a backup every 3 times you exit, so you should hopefully you have some backups more recent than November? You can change your automatic backup settings to backup more frequently, and save more copies if you want.
Who is onlineUsers browsing this forum: No registered users and 18 guests |
