Column widths
Postby 4MoreProfits » Thu Mar 04, 2021 7:37 am
This should be an easy one. When I do a report, Say a Performance and I display it I can adjust the column widths of all columns except the far left one and It is cutting off. How can you expand that last column width?
Jim
4MoreProfits
Postby Mark » Thu Mar 04, 2021 9:17 am
Hi Jim,
To the right of the right-most column header there is a hidden divider that you can click/drag, just like all the other dividers. Hover your mouse there, and you'll see the cursor change when you're over it.
