FX USD to GBO Conversion for Capital Gains report
Postby kosmicmisfit » Tue Aug 24, 2021 9:38 am
Hello
I want to be able to convert all transactions that go into capital gains report by a fixed fx amount.
What is the best way to achive this?
kosmicmisfit
Postby Mark » Tue Aug 24, 2021 9:13 pm
Hello,
Can you give me an example? So, if you bought something for $100 you want to change it to something like $105? Are you trying to add the same fixed amount, or scale by some factor because if currency?
Postby kosmicmisfit » Tue Aug 24, 2021 11:17 pm
DD/MM/YY TRAN SYMB BNUM ANUM CNUM
29/06/2020 Buy ABBV 100 96.51 1.00
13/07/2020 Sell ABBV 100 98.02 1.02
Above prices in USD. Need to convert to GBP for Cap Gains. So Divide Cost & Disposal by say GBP to USD 1.4.
worst case I can fx the data before importing into FM. As I have been doing
kosmicmisfit
Postby Mark » Wed Aug 25, 2021 3:42 pm
You can use the multiple currency feature. You can view your capital gains in either the native currency of the investment or a default currency, and you can choose both of these. See the multiple currency tutorial here:
https://youtu.be/NYfl80EI0b0
