In the Portfolio Performance report I'm seeing dividends as negative amounts.
Why are dividends being reported as negative amounts? Shouldn't dividends be positive as part of the total return?
Thank you.
Negative Dividends
Hi chris319,
It is an option. See: Options / Report Preferences... / Portfolio Performance / Display Removed Money as Negative Value It is documented as: "Any field that removes money from the portfolio will be shown as a negative amount. This includes the Withdrawals, With-Dist., and Distrib. fields." The idea is money you took out of the line item is considered removed, or subtracted from an ending value point of view. The ending value would have been higher if that money hadn't been taken out. Dividends are a positive for returns, but so is ending value.
Who is onlineUsers browsing this forum: No registered users and 5 guests |
