Column header editing
Postby paullayzell » Thu Mar 31, 2022 6:55 am
Hi there
Love the software!
Is it possible to change the text in a column greater? Some of the headings are enigmatic and I would like to replace the text with something I am more familiar with.
Many thanks
Paul
paullayzell
Postby Mark » Thu Mar 31, 2022 7:14 am
Hi Paul,
Only in the Advisor version... In the Advisor version you can use "Options / Report Column Labels..." to change the report column labels. The labels in the Portfolio Editor columns are not user-adjustable in any version.
