Advanced Report Filters/Display in Advisor
Postby OT_Family » Mon Aug 22, 2022 3:13 pm
I've been using the FM Pro version for some years. Now I have extensive data loaded, I'm using an evaluation copy of the Advisor version.
I can see how the client reports eg Executive Summary would help me to support extended family members.
In the Version Comparison Table, Advisor has Advanced Report Filters/Display that the other versions do not. I cannot see what facilities this refers to. Specifically, I was hoping the Filter to Include would allow more than a single value.
Where should I be looking?
Regards.
Martin Tate
OT_Family
Postby Mark » Mon Aug 22, 2022 3:27 pm
Hi Martin,
The advanced report filter is the option to limit the number of hierarchy levels displayed in a report that has sub-totals turned on. In the "Report Settings" dialog if you turn on "Subtotal by" you'll see an option:
Limit Hierarchy to X Levels
The options under the "Filter..." dialog box are the same. You can't include multiple selected items, even in the Advisor version.
