Custom column names
Postby Vandring » Mon Oct 23, 2023 4:53 am
Is it possible to give custom names to report columns? Or force the current report column names to appear on the same line? I am parsing a CSV file from the Open Lots report in a Python script. The CSV file renders the column names over two rows, so I need to prep the csv files before running through the script. I would prefer to avoid doing that, but then I need the column names on one line.
Vandring
Postby Mark » Mon Oct 23, 2023 7:07 am
Hi Vandring,
This feature is only available in the Advisor version. Under "Options / Report Column Labels..." you can customize the column labels of any report.
