Content of the column "Portfolio parent" truncated
Postby Djobydjoba » Sat Feb 03, 2024 3:08 pm
I've created a custom report, and for some reason (a bug?) the content of the "Portfolio parent" column is not completely displayed even if the column is enlarged.
https://i.ibb.co/zh5bRx7/Report-Column.gif
The column next to it (on the right), "Portfolio hierarchy" has no problem to display all the content even if it is much longer.
Any idea?
Postby Mark » Sat Feb 03, 2024 5:23 pm
This field is limited to 49 characters, and in the case you show, where there are multiple parents, if the next parent doesn't fit within 49, it will just end with ", ...". The portfolio hierarchy field allows up to 149 characters.
Postby Djobydjoba » Sun Feb 04, 2024 1:22 am
Understood, thanks.
