Upside/Downside Capture Ratio
Postby swisspm » Sat Feb 17, 2024 1:34 am
Hello Mark, in a report is there an easy way to show the upside/downside capture ratio against an index for an entire portfolio? Many thanks.
swisspm
Postby Mark » Sat Feb 17, 2024 8:50 am
Hi swisspm,
I'm not familiar with this figure. It isn't something built into the program under this name. Can you explain what you want calculated?
Postby swisspm » Mon Feb 19, 2024 3:52 am
Hello Mark,
They measure whether a given fund has outperformed or underperformed another fund or a benchmark during a period of market strength and weakness. The upside capture ratio is calculated by taking the fund's return during a period and dividing it by the other fund’s (or benchmark) return during that period.
see https://www.morningstar.com/articles/37 ... ure-ratios.
I realise that this can be done on a case-by-case basis by creating a blended investment, but it would be useful to have such a measure as a standard formula when creating reports for a large number of funds.
Thanks and regards
swisspm
Postby Mark » Mon Feb 19, 2024 9:04 am
Hi swisspm,
Thanks for the information. It is something we can consider adding. We do have some similar relative statistics you can use for comparing against a benchmark of your choice. See:
Alpha
Beta
Correlation
R-Squared
Standard Deviation of Returns
Sharpe Ratio
