Custom report for Selected Sub-portfolio
Postby paulstonge » Tue Jun 02, 2009 2:13 pm
If I left click an existing sub-portfolio and then select a non-custom report, the report appears for the left clicked sub-portfolio, however when I try this for a custom report I must re-select the sub-portfolio through the settings dialog. Am I missing something?
paulstonge
Postby Mark » Tue Jun 02, 2009 2:36 pm
Hi paulstonge,
I can't reproduce this here. When I select a sub-portfolio and then choose "Reports / Custom..." that select sub-portfolio is selected for display in the Report Settings dialog.
Are you maybe talking about a 'memorized' report instead of a custom report? Memorized reports also memorize the sub-portfolio property.
If you're still seeing this problem with a custom report, please let me know what version you're using, and the exact steps you're taking so I can try to reproduce the problem here.
Postby paulstonge » Tue Jun 02, 2009 4:11 pm
Yes it is a memoralized report, which is the only way I know to save the custom settings, so there is no work around for this, correct?
paulstonge
Postby Mark » Tue Jun 02, 2009 5:05 pm
Hi paulstonge,
Correct. You'd have to change the portfolio by selecting "Edit / Report Settings..." after creating the memorized report.
