Option to turn off "hot link" on reports?
Postby fmuser » Wed Apr 02, 2025 7:21 am
Is there, or would you consider adding an option to turn off "hot link" support for FM reports?
I seldom have any use for the ability to open investment details from a report, but often need to copy the text of the entire report so I can paste it into an editor (e.g. Notepad) and then copy specific fields/numbers in order to paste them into another application (e.g. a spreadsheet).
I believe very old versions of FM supported copy of selected text/fields from a report. I would like to have that behavior/support available.
fmuser
Postby Mark » Wed Apr 02, 2025 8:34 am
Hi fmuser,
I don't think we've ever had the option to select specific text and copy it. You can however use either the top level "Edit / Copy Text" or right mouse click on the report and choose "Copy Text", and that will copy the entire report to the clipboard in text format.
