Recently bought a new system and reinstalled FMA. I have the registry key to import for custom reports et al. However, I did not get the batch print list. Anyway to do that?
Batch printing list
Hi Mike,
I think you're asking about your "client list"? This information is stored in the file "clientdb.fmc". This file is stored in your "Documents \ Fund Manager" folder. You can either manually copy it to your new computer, or if you're using "File / Backup" and "File / Restore" this file is included.
Hi Mike,
You might try searching for clientdb.fmc on your old system. If you can see your client list in Fund Manager, then that file should be present there. Restoring from a backup would work too.
Who is onlineUsers browsing this forum: No registered users and 5 guests |
