In "Graph" Windows are indicated yelds.
The "gph:" yeld is intended as annualized yeld (if 3,5,10 yelds are set so) or as "normal" yeld between starting and finishing date?
Graph and Yelds
Hello mkappa74,
The "gph"yield term above the graphs is for the time period of the graph. Whether or not it is annualized depends on the length of the yield term, and the preferences you have set under "Options / General Preferences... / Yields". By default, those options are set to not annualize yields for terms less than a year, but annualize for terms greater than 1 year.
