Disappearing alerts
Postby richard » Fri Sep 10, 2010 1:02 am
Am using Fund Manager Pro 10.7
If I place a high alert at say $140 with the NAV at $138 and then the NAV rise to $141 the graphical indication of the alert disappears. I get a window opening say alert compleated (standard), but the straight line has disappeared. If I go to edit/alert, i see it as marked complete.
How do I get it to show up on my monitor.
Trailing alerts seem to behave the same way.
Richard Trilling
richard
Postby Mark » Fri Sep 10, 2010 8:11 am
Hi Richard,
This is controlled with an option. See the "Graphs / Options / Display..." menu command from a Graph window. There you will find this option:
Alert Markers Drawn for Active Alerts Only
It sounds like you'd like to turn off this option.
Postby richard » Fri Sep 10, 2010 10:15 am
Thanks, that was it
Richard
richard
