No graph displays of any kind in one portfolio
Postby aneilljr » Sat Nov 12, 2011 5:12 am
I have over 8 portfolios. Seven are displaying perfectly. One will not display any graphs. Report data displays perfectly but no graphs will generate of this data. Help!
aneilljr
Postby Mark » Sat Nov 12, 2011 11:25 am
Hi aneilljr,
What specifically happens when you select one of the graph types from the top level "Graphs" menu? Do you see the Graph window at all? If so, is the graph window just blank? If you don't see the Graph window, try using one of the "Window / Tile or Cascade" menu commands to make sure the Graph window isn't off your screen.
Postby aneilljr » Sat Nov 12, 2011 11:42 am
Using Cascade brought the graph back. Thank you
aneilljr
Postby wizard348 » Tue Apr 10, 2012 8:31 am
This happens to me quite a bit. The first thing I do is go to "View" and check both "Scale" "Date" and "Zoom". Nine out of ten times, one these is not set right.
wizard348
