Display of Symbol on Graph Display
Postby Glenn Hall » Sat Apr 05, 2008 8:11 am
How do I display the Symbol for a stock on the graph screen display?
The Name is displayed but it would be very helpful to display the Symbol identifier especially when the name can be very similar for stocks of the same company and doing a manual audit can be a challenge.
The properties page for a stock list the Symbol and also imports the stock and stores the information by using the Symbol but yet the name is only displayed on the graph screen. I would hope that there is a separate display for this outside of editing the name to display it.
Glenn Hall
Postby Mark » Sat Apr 05, 2008 12:58 pm
Hi Glenn,
Right mouse click on the graph, and choose "Graph Options / Legend Text...". On the dialog that comes up you can edit the legend text for each graph type. You can insert a variety of fields, including the investment's symbol, wherever you want in the legend. To insert a field, put your cursor where you want the field, and choose the "Insert Field..." button.
