Legend Text with graphs
Postby bagmore » Fri Dec 30, 2011 3:50 pm
Hello,
When I create graphs, based on whatever sub-portfolio, there are some fields, which I know can be changed under "legend test".
I see V: (for value I assume) then I see a dollar value which is obviously the value of the sub-portfolio. The next value is in brackets and seems to represent the change in value of the sub-portfolio on the day. This is the one giving me trouble.
No matter what time period I make the graph this value remains constant. How do I make the value in brackets show gain or loss for periods other than the last day?
bagmore
Postby Mark » Fri Dec 30, 2011 8:33 pm
Hi bagmore,
Sorry, that is not a graph legend option. You can customize the graph legend text to some extent by selecting "Graphs / Options / Legend Text...". You can type in text and insert various fields. There is no field for change in plotted value from beginning to end though. That would be a good one to add to the available fields.
