print graphs
Postby gbfabiani » Sat Mar 24, 2012 11:09 am
If we choose to print graph with the option "on colour printers draw the background" they are fine, but the ink consumption is huge!
If we don't choose to print the background, the graphs are hard to be seen ( yellow colour for instance ). I saw colours are customizable, but it is noyt so simple. Would it be possible to have default values in order to save ink but still have a nice presentation ?
giovanni
gbfabiani
Postby Mark » Sat Mar 24, 2012 11:35 am
Hi giovanni,
If you choose "Options / Colors..." you can customize all the graph colors, including the background color. If you take some time to edit your colors for printing, you can then save this as a "skin". You can have multiple skins, so you could have one for display and one for printing for example. You can easily switch back/forth between skins. See the "Options / Skins" menu for commands to memorize and switch between skins.
