by oyz79 » Wed Apr 25, 2012 8:53 pm
I am looking for a way to calculate the following metrics for portfolios, I apologize if these should have been separated out in unique posts:
Max drawdown of a portfolio Annualized portfolio volatility Sharpe ratio of a portfolio Plot the moving average of a portfolios value on the price+distributions graph
oyz79
by Mark » Thu Apr 26, 2012 11:35 am
Hi oyz79,
For the maximum drawdown, that is only available for investments, not a portfolio. The field is "Maximum Drawdown" in a Custom report.
See "Standard Deviation of Monthly Returns" or "Beta" for volatility of a portfolio. These are also Custom report fields.
See "Sharpe Ratio" in a Custom report for the sharpe ratio of your portfolio.
There is no option to plot the moving average of a portfolio's value...
by oyz79 » Thu Apr 26, 2012 7:02 pm
Thanks, I get "N.A." for Beta (end) and Sharpe Ratio (end) for both the investments and portfolio.
Max drawdown of a portfolio would be a nice feature to add on a future release and I would think would be relatively easy to implement since you have the how and low value data
oyz79
by oyz79 » Thu Apr 26, 2012 7:21 pm
Got it, I had the benchmark assigned but the comparison period was too long, prior to the portfolio inception
oyz79
by oyz79 » Thu Apr 26, 2012 7:30 pm
I have noticed on a few portfolios, certain investments still have "n.a." for sharpe and beta. This seems to render the portfolio beta and sharpe "n.a." See attached
- Attachments
- Capture.JPG (145.01 KiB) Viewed 5975 times
oyz79
by Mark » Thu Apr 26, 2012 7:39 pm
Hi oyz79,
Try retrieving historical prices for those investments. You need to have sufficient pricing data every month within the comparison period. If you're missing some prices, you can get an N/A. You can also experiment with the "Yield Interpolation Range" settings to loosen up the interpolation rules. A better solution is to just get all the historical prices for these investments.
by oyz79 » Thu Apr 26, 2012 8:00 pm
Thanks, got it.
One final question - are all the calculations for the period the report was run, or for the period the stock was held?
oyz79
by Mark » Thu Apr 26, 2012 8:29 pm
These calculations are for the comparison period back from the ending report date.
