Graphs wont display - version 10.8
Postby Paul King » Sun Sep 28, 2014 12:07 am
Hi - since adding a second GPU to my system, Fundmanager graphs no longer display as before.
Clicking a graphing option causes a momentary flicker, then I see an otherwise empty app window.
Reports display normally
Workaround is to click the 'new window' menu option first , but this was never required before - a new window was automatically opened when clicking a graph menu option.
Paul King
Postby Mark » Sun Sep 28, 2014 9:37 am
Hi Paul King,
Maybe the graph window is positioned off your screen somehow. Try selecting the graph type you want, and then choose "Windows / Cascade". That will put all your open windows into the restored state, and position them starting from the top/left of your Fund Manager window. Hopefully that will allow you to see your Graph window. You can then position it where you want, or maximize it.
Postby Paul King » Sun Sep 28, 2014 2:14 pm
Mark wrote:Hi Paul King,
Good call! that was the problem - thanks!
Paul King
