Cost-Value
Postby rupertpage » Mon Sep 07, 2015 2:04 pm
Hi Mark
On this graph I have the blue value line and the black cost line
I also have some purple lines which I cant quite work out what they represent exactly....is it possible to edit them out ?
rupertpage
Postby Mark » Mon Sep 07, 2015 8:17 pm
Hi rupertpage,
I'm not sure, are you seeing markers or trendlines? If you select "Options / Markers / None", does that turn them off? If so, you might try turning on each type of marker one at a time, so you can see what type of markers are in question. If that isn't the issue, maybe you can post a sample screen shot.
Postby rupertpage » Thu Oct 22, 2015 9:25 am
Thanks Mark
It was "Alert" makers
rupertpage
