Is this possible?
Postby larryw » Tue Feb 02, 2016 5:20 pm
I have a master portfolio (All) with 3 sub-portfolio investments (One, Two, Three)
I'd like to display a portfolio value graph for each on one screen, Ie set number of displays to 4.
Can I do that in Personal version?
larryw
Postby Mark » Tue Feb 02, 2016 8:53 pm
Hi larryw,
Not in the same graph window. Portfolio based graphs only plot a single portfolio at a time. You can however create 4 graph windows, and set each window to display for a different portfolio. From within an existing graph, select "Graphs / New Window" to create a second graph window. Each graph window is independent, so you can select the active portfolio from the "Portfolio" top level menu. You could then arrange these 4 windows, so you can see all 4 at once.
