Quality of copied graph
Postby stegra » Thu Apr 28, 2016 3:08 am
Is there any way to format the graph in order to have better quality when I copy the graph into word or excel?
Please see two images attached. The quality gets a little better when I do a screenshot of the graph.
Thanks!
screenshot graph.png (59.55 KiB) Viewed 2708 times
graph copied into word.png (38.07 KiB) Viewed 2708 times
stegra
Postby Mark » Thu Apr 28, 2016 7:33 am
Hi stegra,
How are you copying this into Word? Are you using the Advisor version? If so, use "Edit / Copy to Clipboard" and then paste it into Word. It helps if you size the window in Fund Manager to the size you want in your Word document first. Then, once you paste it, right mouse click on it, and choose "Format Picture..." and set the "Size" to 100% keeping the aspect ratio the same. See this example:
pasted and sized in Word
Postby swisspm » Mon May 09, 2016 12:39 am
Hello Mark,
I'm having similar problems with printing graphs using the personal version. If, for istance, i am viewing a graph and then click on file / print / preview, the quality is very rough, like the bottom image below from stegra. The quality on the screen is fine so somehow it gets lost when printing. Is there a way, with the personal version, to print (paper or pdf) high resolution versions of the graphs?
Thanks and regards
Pierre
swisspm
Postby Mark » Mon May 09, 2016 7:23 am
Hi Pierre,
I believe stegra was having issues with the sizing of copying/pasting from the Advisor version. That is different than printing and print preview. Printing is done at the full resolution of your printer. The Print Preview is showing a scaled version of your printer output on the screen. Depending on the size of your window and screen/printer resolution the display on the screen may not look as good. If you actually print to your printer (or PDF file), does it look high resolution?
