"C" Hotkey while Viewing Cost - Value Graph
Postby B2B_Investing » Thu Apr 28, 2016 5:44 am
Hello Mark,
I accidentally keyed "C" while viewing a cost-value graph and noticed that is adjusts the Cost Line. Can you help me understand which is being toggled?
Jason
B2B_Investing
Postby Mark » Thu Apr 28, 2016 7:39 am
Hi Jason,
The "C" key toggles the cost option between "Historical" and "Current". See the menu command "Graphs / Options / Historical cost". In "Historical" mode your cost is since inception. In "Current" mode, it is only the cost of the currently owned shares. Consider the case:
Buy 100 shares for $1,000
Sell 75 shares for $900
In "Historical" mode, the cost of those remaining 25 shares is $100. In "Current" mode, the cost is $250.
For more of an explanation, see the documentation:
https://www.fundmanagersoftware.com/hel ... stval.html
Postby B2B_Investing » Mon May 02, 2016 3:22 am
Hello Mark,
That helps a lot. I noticed that as I exited and then later reentered a position the cost could graph as negative. This helps quite a bit. Thanks,
Jason
B2B_Investing
