Uploading Price Data in csv format
Postby SDS » Thu Sep 18, 2008 9:03 pm
Mark, I took your suggestion in downloading price data in csv format, but still can't download as the data does not appear to match any of the input formats.
The price data I'm attempting to download is volatility on the Eurostoxx50, and all that's included is the date in the format 04.01.1999 with a semicolon followed by the volatility number itself.
Seems like it should be simple enough to chart this basic format. Hopefully, I'm overlooking something simple but essential to get this done.
SDS
Postby Mark » Tue Sep 23, 2008 10:31 am
Hi SDS,
Please note, you can type your own format strings, you aren't limited to the ones listed in the drop-down. Those are just the most recent ones. You can enter your own format string right in there. Press the "Help" button for instructions, but it sounds like you'd use a format string of:
MM.DD.YY;NAV
