Negative Performance following Transfer
Postby smacrae » Sat Jun 24, 2017 10:13 am
I moved a significant portion of stock from one account to another. Now the returns across the top of the graph (and reports) are all significantly negative - like -98%.
This is somehow based on the reduction in value of the account. but the performance isn't negative - do I have to adjust a setting somewhere?
smacrae
Postby Mark » Sat Jun 24, 2017 10:59 am
Hi smacrae,
Look at the transactions you entered to move the stock. Did you use the Transfer Between wizard? Did you enter a "Market Value" in the wizard for each transfer?
Postby smacrae » Sun Jun 25, 2017 6:19 am
No - I did not; when I entered the market value its fixed the problem.
Thanks!
smacrae
