Moving Average Options
Postby SDS » Fri Oct 10, 2008 5:01 pm
When using moving averages, it is highly useful to have 1 simple moving average for the shorter term, and perhaps 1 or 2 exponential moving averages for longer periods. Thus far, it only appears feasible to apply either 2 simple moving averages or 2 exponential moving averages. Is it possible to apply 1 SMA and 1 EMA to the same chart? If not, this would be a highly useful feature.
SDS
Postby Mark » Fri Oct 10, 2008 10:09 pm
Hi SDS,
Thanks for the feedback. You're right, you can't have both SMA and EMA on the same graph at the same time.
Postby SDS » Fri Oct 10, 2008 10:56 pm
Uh, how much would it cost to get this feature in place ASAP?
SDS
Postby Mark » Sat Oct 11, 2008 9:12 am
Hi SDS,
This is not a feature we'd consider adding before at least a 10.0 release, which is probably 1 1/2 years away. Even for 10.0 I cannot promise it will be added. We evaluate all feature requests/ideas, and implement the ones we believe will have the broadest benefit.
If you need this feature, we do offer custom programming services. Our rate is $150/hour, with a minimum of 8 hours. If you're interested in pursuing this, please email us. We will need to nail down an exact definition of work, and then we can give you a quote.
