X Axis fails to revert
Postby aldenxi » Thu Oct 26, 2017 12:38 pm
A few days ago I inadvertently hit the H key which caused my graph display for one stock to show only one months data. I the hit the R key ( and X & home keys) all of which returned the full x axis date range display. I then saved any changes along the the full display and closed FM. Nevertheless, when I open Fund Manager it always shows only a 30 day graph for this particular stock. How do I make the default X axis for this stock show the full date display?
John A.
aldenxi
Postby Mark » Thu Oct 26, 2017 4:02 pm
Hi John A.,
Set the date range the way you want it. You can use "View / Dates...". Then, use "File / Save Portfolio". If you then exit, and re-start your date range should come back the same as it was before.
