Graphical cost definition
Postby richard » Mon Oct 20, 2008 11:04 am
Is there any way to change/redefine the cost of an investment. I have several cases where an investment entering into a portfolio has a previous cost associated with it or where the cost cited is not appropriate.
Yours,
Richard
richard
Postby Mark » Mon Oct 20, 2008 11:32 am
Hi Richard,
Yes. The cost is calculated from your recorded transactions. Just edit the recorded transactions, to adjust their cost to the correct value. You can do this in the Data Register with the data type set to "Investments (all)".
Postby richard » Mon Oct 20, 2008 11:37 am
That way I know. Is there any way to do it independently of my recorded transactions on a given date?
Richard
richard
Postby Mark » Mon Oct 20, 2008 12:06 pm
Hi Richard,
You can only specify the cost in the transaction details. Is there some problem you're running into with this method?
Postby richard » Mon Oct 20, 2008 12:34 pm
The problem I'm running into is due to me . I was very careless in the past, so some of my graphics have the wrong cost. Some of this is/was due dividends return as stock, other reasons I'm not even sure of. What I'd like to be able to do is have the graphical costs reflect the numbers that my broker has.
richard
Postby Mark » Mon Oct 20, 2008 12:40 pm
Hi Richard,
By 'graphical costs', do you mean the markers on the graphs? If so, these are based on the cost you have recorded for that transaction. It sounds like you may need to just update the cost recorded in your transactions, to match your broker's statements.
Postby richard » Mon Oct 20, 2008 11:20 pm
No I mean the line that represents the cost and the number in the upper left hand corner of the cost-price graph.
Richard
richard
Postby Mark » Tue Oct 21, 2008 10:21 am
Hi Richard,
That cost line is also from your recorded transactions. If you record all your transactions with the correct cost, then this line will be plotted at the correct cost (as determined from your transactions).
