Charting Advancing?Declining Issues; Volume on NASDAQ
Postby SDS » Tue Oct 28, 2008 1:12 pm
Using one of the quote services utlized by Fund Manager, is it possible to somehow capture the following historic data in a format that may be charted separately:
1) daily number of issues advancing on NASDAQ
2) daily number of issues declining on NASDAQ
3) daily volume of issues advancing on NASDAQ
4) daily voilume of issues declining on NASDAQ
I'm hoping to chart the above data over the past couple of years at least, if possible, for my clients. But I know this is not the sort of thing Fund Manager is really designed to do. Would appreciate any suggestions you might offer if FM can be used for this purpose, though.
Many thanks for any response[/b]
SDS
Postby Mark » Sat Nov 01, 2008 10:07 am
Hi SDS,
Unfortunately, I don't have a solid answer to your question... Fund Manager
can retrieve anything with a symbol on our supported quote servers. If you
can find a symbol that provides this information, then you can retrieve it.
I'm not aware of any symbol for these items though.
