Can't Open 2 Graphs At Once
Postby ASU » Sat Mar 31, 2018 6:06 pm
I can't seem to be able to open 2 graphs at once. I want to open a pie graph and a portfolio value graph at the same time. I'm doing this so I can batch print/email these graphs (along with multiple reports) to clients.
ASU
Postby Mark » Sat Mar 31, 2018 6:24 pm
Hi ASU,
You can open a second graph window using "Graphs / New Window..." from within the currently opened graph window. You can then change the graph type/settings to whatever you want, and you'll have two open graph windows.
Postby ASU » Sat Mar 31, 2018 7:33 pm
OK Thanks, that works.
Also, when I'm batch emailing it seems the graph(s) show up first regardless of the order I put them in the print order.
ASU
Postby Mark » Sun Apr 01, 2018 10:24 am
Hi ASU,
Are you talking about the .jpeg attachments to the email that is created? If so, yes, those are added to the email in no particular order. The ordering only applies if you are printing. We can try to make the attachments be added in the same order in the future, that would be better.
Postby El Gordo » Thu Jan 17, 2019 12:31 am
I had no purpose to open two graphs at once, but I read the post and tested the operation merely to experiment. I LIKE IT! Although I don't really need to perform this action, it is cool. I wish it would print this way (i.e. both graphs on same sheet)
El Gordo
El Gordo
