Graph Legend Text
Postby Jimbo » Wed Sep 26, 2018 6:19 am
Looking for a way to display the subport file name on a graph. This was discussed in a previous post. I would like to see Sally Port on the graph. Any ideas? and I just upgraded to 2018 version- longtime user.
Ex
Master Port
Jim Port
Sally Port
Jimbo
Postby Mark » Wed Sep 26, 2018 10:39 am
Hi Jimbo,
The ability to customize the legend text, including inserting a wide variety of fields, is available in the Advisor version of Fund Manager. If you're using the Advisor version, right click on the graph, and choose "Graph Options / Legend Text...". See the "[[SUBPORT]]" field to display the sub-portfolio wherever you want in the legend.
Postby Djobydjoba » Wed Sep 26, 2018 11:02 am
This ability is available in the Professional version too.
Postby Mark » Wed Sep 26, 2018 11:19 am
You're right, thanks for the correction Djobydjoba.
Postby Jimbo » Thu Sep 27, 2018 7:12 am
Thanks for the reply- I do have the [subport] option for legend text, just nothing populates. Must be because I a have the Personal version....oh well.
Jimbo
Postby Mark » Thu Sep 27, 2018 9:22 am
Hi Jimbo,
I really blew the original answer to this question. The ability to customize graph legend text is available in all versions. The Advisor version does offer additional fields for inserting, but all versions allow you to customize the legend text. It should work fine for you to insert the [[SUBPORT]] field. Notice there are 2 double square brackets, and not 1. Also, the letters are all upper case. If you use the "Insert Field..." button in the dialog that will allow you to make sure the field is inserted properly.
