Missing % Values in Pie Charts
Postby Jarmila » Mon Oct 22, 2018 3:45 am
I have the Professional version and no matter what Pie Chart I try to do, the % values do not show up in the legend - picture is attached.
What am I doing wrong?
Thank you
Jarmila
Jarmila
Postby Mark » Mon Oct 22, 2018 8:47 am
Hi Jarmila,
It looks like your % figures are colored the same as the background. Try going to "Options / Colors..." and select the color "Axis label text", and change that to something you can see on your white background.
On a related note... If you're experimenting with different color schemes you can use skins to remember your different settings. See "Options / Skins" to memorize or recall different skins.
Postby Jarmila » Mon Oct 22, 2018 11:25 am
Dear Mark,
this works thank you !
Sincerely
Jarmila
Jarmila
