Reinstalled FM, Lost Some Customizations
Postby El Wealtho » Fri Dec 21, 2018 9:57 pm
FWIW, reinstalling FM meant re-customizing Graph Legend Text and Category Labels - so far. Not sure if missed something at this end ...
Thx
El Wealtho
Postby Mark » Sat Dec 22, 2018 8:30 am
Hi El Wealtho,
If you "uninstall" Fund Manager that will cause your preferences from the registry to be removed, and you would see what you're describing. Typically if you are installing a new version it is recommended to just install the new version, right over the old. Do not uninstall the old version first.
You can restore your preferences to the registry from a *.FMB backup. Use "File / Restore..." and you can select the Global Registry Preferences, and choose to only restore the selected item.
Postby El Wealtho » Sat Dec 29, 2018 12:50 am
Had to "Reset" Windows 10, which deletes most apps, then reinstall FM. I gather "Restoring" rather than "Opening" the FMB file was the route to go?
El Wealtho
Postby Mark » Sat Dec 29, 2018 11:11 am
Hi El Wealtho,
Yes, when you restore from a *.FMB file you have the option to include restoring all the global registry preferences.
