Portfolio chart is blank
Postby kosmicmisfit » Mon Dec 24, 2018 2:13 pm
Hello
There were some erronous transactions and I adjusted them and since then Portfolio gain chart is blank so is the port value chart for this particular portfolio.
Any suggestions on what could be wrong?
thanks
kosmicmisfit
Postby Mark » Mon Dec 24, 2018 2:18 pm
Hi kosmicmisfit,
Do you see the axis, or do you not see those either?
Make sure "View / Graphs" is turned on. You might also need to reset the graph Y axis and/or the X axis. Use "View / Scale..." and "View / Dates...".
