Only N.A. on Yield Display on Portfolio Gain Graph
Postby El Wealtho » Wed Feb 06, 2019 3:02 am
Have always been able to see ROI (or TWR) yields on the Portfolio Gain graph for the periods I specify. Now I am getting nothing but N.A. (FM Version 2018)
Have monkeyed around with Yield Interpolation Range to no avail. And, anyway, had not touched that.
This may have come about when I had to reinstall FM and opened a .FMB file rather than restoring it.
Thank you sirs.
El Wealtho
Postby Mark » Wed Feb 06, 2019 8:50 am
Hi El Wealtho,
If you look under "Help / Logs / Graph Calculation..." that should explain the reason for any N/A figures.
Postby El Wealtho » Wed Feb 06, 2019 10:47 pm
Your answer seems to have led to the resolution. Also, I had currency exchange rate items mixed in with the portfolio (for ease of viewing); needed to remove these, as was suggested as a tip in one of your help files. :o
El Wealtho
Postby Mark » Thu Feb 07, 2019 9:11 am
Hi El Wealtho,
Very good. Another tip is:
Investments assigned to an exchange rate and investments of type "Exchange Rate" are not adjusted with View / Exchange Rate Adjusted. It is recommended to assign such investments to the default currency, so that if/when they are included in a report, they do not cause (na) values due to summing across currencies.
