Copying a graph
Postby surendar jeyadev » Sat May 23, 2020 5:17 pm
I would like to copy a simple graph (value vs time). The 'Help' says
"To copy a graph image to the clipboard use Edit / Copy to Clipboard from the Graphs window. To copy a report image to the clipboard use Edit / Copy Picture from any Report window."
I have produced the graph by selecting Graphs/Portfolio Value. It looks fine. But, when I go to Edit, I do not see 'Copy Picture'. The options under Edit are Internet Retrieve, Update Price, Delete Price, Buy/Sell, etc. Obviously, I am doing something terribly wrong!
Can you explain how I can copy (or, export) a graph?
thanks
sj
surendar jeyadev
Postby Mark » Sat May 23, 2020 6:06 pm
Hi sj,
That feature is only available in the Advisor version. What version are you using?
Postby surendar jeyadev » Sat May 23, 2020 6:31 pm
Ah! I am using the Personal version.
Thanks. I will export the data and plot it.
surendar jeyadev
