Default graph time scale
Postby Ilikemybu » Tue Apr 27, 2021 5:28 am
I find myself typically want to see a time scale of 3 mo for my graphs. It seems they always open defaulting to PRC. I've tried using Shift then selecting the date range from the pull down. I thought you said that set the graph for all open investments to that date range. It seems to do it temporarily, but doesn't seem to stay. I really can't figure out what it does, or how to change the default opening.
Dave
Ilikemybu
Postby Mark » Tue Apr 27, 2021 9:56 am
Hi Dave,
If you close a graph window, all the preferences are lost. If you leave it open, and save it as part of your portfolio file, it will retain your preferences.
