Detachable window for Graphs
Postby Arrow » Fri Apr 22, 2022 6:26 am
I use to work with multiple monitors.
Is it possible to detach a window only for the graphs?
If not do you think it will be feasible in the future?
Thanks for your answer
Arrow
Postby Mark » Fri Apr 22, 2022 9:39 am
Hi Arrow,
Right now, you can't separate a graph window from the main frame window. However, if you wanted, you could start multiple copies of Fund Manager. To enable this feature, turn on "Options / General Preferences... / Other / Allow Multiple Program Instances".
Postby Arrow » Fri Apr 22, 2022 10:05 am
thanks for having pointed out an unknown feature to me.
When I need to close the multiple program instances, according to the fact that closing FM it memorizes the changes, which priority criteria do I have to follow?
Arrow
Postby Mark » Fri Apr 22, 2022 10:34 am
Hi Arrow,
You could do this in various ways, but one option is to just make changes from one instance only. You can also turn off the "Options / Save <portfolio/investments> On Exit" options. This gives you more control. If you exit without saving un-saved changes, FM will prompt you to save. If you have 2 copies of the program running at the same time, you don't want to make changes in both. Only the last saved copy will get its changes saved.
