Date range for graphs
Postby senior » Sat Oct 01, 2022 1:23 am
I want to change the date range in the graphs to a ten year span and found in the online help the following:
Usage Tips:
When the Dates... toolbar button () is enabled, there will also be a dropdown combination box on the toolbar that allows you to quickly select from a variety of common date ranges:
1W 1 Week span ending on the default ending date
2W 2 Week span ending on the default ending date
3W 3 Week span ending on the default ending date
1M 1 Month span ending on the default ending date
2M 2 Month span ending on the default ending date
3M 3 Month span ending on the default ending date
6M 6 Month span ending on the default ending date
1Y 1 Year span ending on the default ending date
2Y 2 Year span ending on the default ending date
3Y 3 Year span ending on the default ending date
5Y 5 Year span ending on the default ending date
10Y 10 Year span ending on the default ending date
MTD Month To Date: beginning of the default ending date month to the default ending date
QTD Quarter To Date: beginning of the default ending date quarter to the default ending date
YTD Year To Date: beginning of the default ending date year to the default ending date
PRC Price inception: date of your first recorded price to the default ending date
TRN Transaction inception: date of your first recorded transaction to the default ending date
... custom date range, select this to open up the View / Dates... dialog
The drop-down menu shows (instead of the above mentioned items) only the following graph date selections
custom
today
yesterday
1 week
1 month
3 months
12 months
earliest price to date
earliest transaction to date
week to date
month to date
quarter to date
last week
last month
last quarter
last year
current week
current month
current quarter
current year
So how can I select a ten year span until the default ending date?
I use FM personal 2022.17.3.100
Greetings,
Peter
senior
Postby Mark » Mon Oct 03, 2022 10:35 am
Hi Peter,
Those date ranges are for a report. Make sure you're looking at the drop-down on the toolbar, while you have a Graph window selected. It should look like:
Graph date drop-down
Postby senior » Mon Oct 03, 2022 10:33 pm
many thanks for your help. That was exactly the info I needed.
Greetings,
Peter
senior
