Cost Price Trend line Colors
Postby 4MoreProfits » Tue Dec 20, 2022 8:05 am
I know where to find the color changes for the graphs, but I can't find which line name is for the cost trend line on the Cst-Price graph The graph has two lines the price graphed against time and the value graphed against time
The price line Name is = Nav lines/Upper TA 1
The Value line Name is = ???????
Could you give me the name of the value line so I can change the color
Thanks, Jim
4MoreProfits
Postby 4MoreProfits » Tue Dec 20, 2022 8:25 am
Mark, I found that if I change the line NAV Overlaid/MA/Upper TA2 would changer my cost basis line. How is one of the main trend lines of the graph type called
Overlaid - when it is one of the two variables of the trend
MA (Moving Average?) - it is the cost basis not an average
Upper TA2 - I have no idea of what this means
4MoreProfits
Postby Mark » Tue Dec 20, 2022 10:20 am
Hi Jim,
For the graph: "Graphs / Cost - Price" there is a "Price" line and a "Cost" line. Each are controlled by these colors:
Price: NAV lines/Upper TA 1
Cost: NAV overlaid/MA 1/Upper TA 2
Admittedly, these names are confusing, but let me try to explain. The same colors are re-used in the NAV based graphs as well as the Technical Analysis (TA) graphs, so when in an NAV based graph, these 2 choices are:
NAV lines
NAV overlaid 1
Where the price is the "line", and the cost is the first overlay. The label:
is trying to say that in the NAV based graphs it is the first overlaid line, and also the first moving average (MA) in the NAV based moving average graphs (Graphs / Moving Average / Share Price). In the Technical Analysis graph it is the second color for the upper section. The first color being the closing price, and the second color being the first SMA. These are documented in the TA graph help.
